Razer blade pro 17 with RTX2080
raymcfarland
Post by raymcfarland »
I just purchased the new Razer blade pro with the RTX2080.
I then heard that Resolume and Windows is having issues with the 2080.
During my 1st and perhaps last show using this laptop, I couldn't get the GPU to push past 28% with a frame rate hovering around 27-29 FPS. This frame rate didn't budge even though I had only 1 1080 DVX3 playing with no effects.
Thoughts?
Yuckfou157
Re: Razer blade pro 17 with RTX2080
Post by Yuckfou157 »
Hi, not wanting to be a bitching ass, the forum has a search ;)
viewtopic.php?f=12&t=18719
viewtopic.php?f=12&t=18279
Programfeed
Post by Programfeed »
Yuckfou157 wrote: Tue Aug 20, 2019 01:48 Hi, not wanting to be a bitching ass, the forum has a search ;)
FWIW, I have this exact same laptop, have followed every screenshot and suggestion in those threads, and am getting the same performance issues.
Programfeed
Here are screenshots of all my settings on Razer Blade Pro 17". You can see in the last one that despite "correct" settings, opening a Windowed Output on my GUI screen shows that Intel is rendering there. I believe this is why performance is getting crushed with any kind of external display hooked in.
I additionally tried setting the texture renderer to High Performance in NVidia settings, but that didn't make any impact on performance and caused the videos to stutter and look generally bad.
https://www.dropbox.com/sh/klswgez8oru9 ... BJCra?dl=0
@yuckfou157 any ideas or suggestions?
@zoltan any other things to try here?
Edit: Nvidia driver 436.02, Windows 10 Pro 64-bit v1809, build 17763.678
raymcfarland
I did search for it and found nothing so yea you're a bitch ass.
raymcfarland
Programfeed wrote: Mon Aug 26, 2019 14:02 Here are screenshots of all my settings on Razer Blade Pro 17". You can see in the last one that despite "correct" settings, opening a Windowed Output on my GUI screen shows that Intel is rendering there. I believe this is why performance is getting crushed with any kind of external display hooked in.
Thank you for the straight up reply. I'm going to go back to the GTX 1080 that worked fine. I returned the Razer. So much for upgrading to the RTX.
raymcfarland wrote: Thu Aug 29, 2019 02:13
so you've tried to search for "Razer low FPS", right?
search.php?keywords=razer+low+fps&terms ... mit=Search
