low number of video frames
sho
Post by sho »
My system:
cpu: 10900K
ram: 8G x 4 (3200HZ)
SSD: samsung 970 p
GPU: rtx3080 X 2
output: 2x(4096*2160) , 2x(3840*1080) , 1X(3840*1440) , 1x(1920*1080)
The problem is
Whenever these screens are loaded in Advanced, the video frames will be less than 20 frames,without playing any video files
Is there a solution to this problem?
thank you!
Re: low number of video frames
Using multiple GPU-s always comes with a performance hit.
You can get the best performance outputting only from the renderer GPU directly.
Here are some options to drive many displays: viewtopic.php?f=7&t=15035
