Layer State
Layer State
Is it possible to have a layer feedback when a layer state is "Populated" or "None Populated" via MIDI ?
Re: Layer State
https://resolume.com/support/en/midi-shortcuts#midi-out
What you're looking for is the "Status"
Re: Layer State
I know how to configure midi status.Arvol wrote: Sat Jan 08, 2022 22:41 https://resolume.com/support/en/midi-shortcuts#midi-out
I will better explain what I want to achieve:
Lets say I have 4 layers, 3 layers contain running clips while the 4th layer is empty.
I want to have 3 midi buttons light up where the clips are running whlie the 4th button's light is off.
* I want to see the status of the layer, Empty or Populated
Re: Layer State
Map that button to a value of 0 on that layers playhead and leave it on "this layer" mapping mode. Then adjust your on/off led color. so when the playhead is at position 0 the light will be off, but anytime a clip is playing the position will not be at 0 and the led will be on.
Re: Layer State
Thats a neat trick!Arvol wrote: Sun Jan 09, 2022 21:04 Map that button to a value of 0 on that layers playhead and leave it on "this layer" mapping mode. Then adjust your on/off led color. so when the playhead is at position 0 the light will be off, but anytime a clip is playing the position will not be at 0 and the led will be on.
