Transition delay between clips
lwhitney
Post by lwhitney »
New to resolume. Running Arena 7 on a 2019 Mac Pro tower with 3 4K outputs. Software is controlled via grandMA2. On the console, if I set the transition time at X seconds and then trigger a clip, it takes X seconds to start the transition and then another X seconds to actually transition, which is not ideal in the least.
Example:
Layer transition time set at 4 seconds. Trigger new clip and a green “load bar” type thing shows up on the thumbnail for 4 seconds, THEN the 4 second transition starts. I have no idea what’s going on so any help is appreciated.
Re: Transition delay between clips
Your clips are set to BPM sync, the bar shows the beat grid position till the trigger.
try setting them to Timeline: https://resolume.com/support/en/video#playback
