Different transition time between clips
Anexus
Post by Anexus »
Hi Everybody,
Does anyone know if there is a simple way to have different transition time betwen clips without manually changint it all the time?
I need some of the clips to cut quickly and others change with a long or medium transition time
Or, any way to set transition time for whole columns instead of layers?
Thank you!
Re: Different transition time between clips
I've made an app a while back for my theatre shows which could do that. https://palffyzoltan.hu/?url=controller
