Just a question about using the BPM function with a standard DJ Mixer line out.
I want to be able take a line out from a Dj mixer and run it into my labtop somehow to work with Resolumes BPM clock. Is there anything out there in Midi world or the audio world that will take a line out signal from a DJ mixer and send a BPM signal that Resolume can recognise?
I've worked with Ableton and had no problems but would love it if I could just plug in to any mixer at a whatever club and be able to sync up my visuals.
Anyone got any ideas?
						Receiving a BPM signal from a standard DJ Mixer
				stanleystark
the only solutions i know of are hardware based...
you can check out expensive dj mixers like the allen & heath series with bpm counter with midi clock out
http://www.xone.co.uk/3d.htm
or the pioneer effect machines efx 500 and efx 1000
http://www.pioneerprodj.com/
there is another solution but i dont have the link now..
if have been looking for a software solution and have found none... it would be great if someone found something usefull and cheaper
				stanleystark
this mixer also does the job
http://www.rolandus.com/products/produc ... jectId=167
this is not yet out, but should be a cheaper solution
http://www.redsound.com/products/soundbitemicro
the same company used to have the voyager 1 which they seem to have discontinued.. here is a link were you can still see it, and some stores might have it in stock
http://www.dooyoo.co.uk/dj-equipment/re ... voyager-1/
for the pioneer i dont think you can asign anything to its knobs, buttons, etc... i will check it out in november because a friend has it and is giving it to me to play for a couple of days.. i will keep you posted..
if you find a software based version to do this, let me know.. i am really interested.. i dont want to take so many things with me to gigs..
