hi,
i'm wondering what you thik about this mobile machine :
Processor Intel ® Core⢠Duo Processor T7200 (2.00 GHz, 4 MB L2
cache, 667 MHz FSB)
Chipset Intel® 945GM
Memory 1024MB 533MHz Dual Channel DDR2 SDRAM (2x512)
Two user accessible SoDIMM sockets
Hard Drives 120GB (5.400rpm) SATA Hard Drive
Graphics 256MB ATI® MOBILITY⢠RADEON® X1400
HyperMemory(TM) graphics card
I'm not so sure about  this graphics card, because
i don't know whether is it good enough for the resolume.The graphic gard can not be changed because it is fixed for this configuration by the DELL.
[Edited on 13-10-2006 by marty]
						Ati X 1400
read deeper into some hardware posts. Video card is basically irrelevant for resolume, as it uses cpu for all it's video processing. As long as it has a tv out option. Don't know that specific processor, but it should be enough for resolume. The dual core is also irrelevant for resolume, but i know it helps with a lot of other things, so it's no reason to turn away from it. I have a dual core. The hard drive though - it's really not good enough. you need at a minimum a 7200rpm drive... You could always go external to get this speed, but i find it helps if all your hard drives are fast. Personally i use raid to achieve this.
