Operating System: Windows XP SP2
Processor: Core 2 Duo 6800 (2.93ghz)
Videocard: Quadro FX 3450
File type: .AVI
Codec: Matrox Codec from the Matrox x.100 720x480
Hello,
I've had this happen to me several times now, every so often. Layer 2 will stop displaying clips. A clip will load in layer 2, but it is not displayed on the screen. This is with opacity at 100%.
Not sure what the deal is there.
Jon
layer 2 stops responding
This may be simple however, when first playing around with the program, I too had this happen. only to realize that their is an on/off button on the left side of the layer that disables and enbles that layer from being seen. this is different from close button next to that removes the clip from the layer. perhaps you accidentally pressed that button.
hope this helps.
Unfortunately not, I use the layer disable function all the time and know that sometimes out of the blue, layers stop working.
Have not been able to put my finger on an exact pattern or process to replicate the fault either.
When a layer âdiesâ clips will not play back on that particular layer whatsoever â a program restart is the only fix.
