midi mapping - set shift, ctlr, alt state
flo
Post by flo »
Can anyone explain me how the "set shift, ctlr, alt state" functions in the midi mapping section works and what they exactly do?
I just don't get it...
thanks
flo
gdlt
Post by gdlt »
Those are replacements fot the same buttons on your keyboard,
If you for example hold down the alt key while dragging a effect to a channel, the intensity slider of the effect will be put on zero instead of 100%.
Or when te alt button is down and pressing on a channel you will remove it instead of activate it.
Look into the manual for more functions.
flo
Post by flo »
Thanks for your reply, that sounds very logical to me.
In fact this function of defining the alt, ctrl, and shift keys on my midi-controller does not work in my setup. My midi-controller works fine but the definition of these keys don't. Maybe I'm missing something... have you tried to use this function on your machine?
