Midi Mapping "other notes" Bug
.mrt
Post by .mrt »
Hey all,
just bought a KORG nano KONTROL - USB midi Controller and tried some midi mapping in resolume 2.4.1 today.
Controllers work fine,
with the exeption of the effect parameters (1 to 4) for layers and effect slots
Other Notes dont work at all...
resolume does not recognize the right midi controller numbers. the same button will show up with the right number in the Controllers collum and with a wrong number in the notes collum... (?!?)
also its always the same number for different controllers or buttons at the other notes collum.
i found this post
http://www.resolume.org/forum/viewtopic ... 0dd#p10675
offering not to connect via USB as a fix. unfortunately the nano series only offers USB connection.
downloading and installing the KORG midi usb drivers and the configuration tool didnt solve the problem...
i found some posts in this forum but no fix which worked for me, maybe i just made a stupid mistake or something...
(...by the way, i still dont really get what the channel notes are doing. i cleared the active one while trying to get the recording to work... ...good/bad/doesen't matter ?? )
I am really looking forward to using midi control for my visuals and i need some of the functions provided in the notes collum as well as the effect parameters.
if anyone of you has a fix or a suggestion please let me know!
my next gig is in a week and tomorrow evening is a rehersal...
My System:
FSC Amilo
Nvidia Gforce 6800
win XP
Intel pentium M processor 2.0 Ghz
2 gig Ram
thanks in advance .mrt
.mrt
Re: Midi Mapping "other notes" Bug
Post by .mrt »
ok.
i've got a clue...
some of the buttons can only send CC or MMC and no notes...
for those ones i used this workaround:
http://www.resolume.org/forum/viewtopic ... cbc7#p5771
cheers .mrt
p.s. visit http://visuals.martinlorenz.at/
quicksnail
Post by quicksnail »
I just got a Korg Nano Kontrol. I've set it up with Resolume 2.41 and everything works fine. I was having trouble at first with the buttons not sending notes. But I figured it out, it does not need a workaround solution. You need to make sure that you send the configuration to the controller after you have it set in the Korg editor software. After that it works like a charm!
hope this helps someone.
Godzil
Post by Godzil »
I going to get my KORG nano KONTROL next week.
So if somebody wants to share his preset file for R2.41 and for R3 WILL BE APPRECIATED :D
