hello, good job i love this software (i mean 2.4)
and i wanted to download the new version..
i download the avenue version and i had problem with avi files.
i just cant load them i dont why.
i mean i am pressing on them double click and its not working.
i tried to drag them and its doesnt work too.
i tried on another computer and guess what ?
well its not working too..
in version 2.4 its worked well..
problem with loading avi files
Re: problem with loading avi files
Could you send us one of your files so we can see what the problem might be.
Send it to mail AT resolume.com
yea sure thank you for helping meedwin wrote:Could you send us one of your files so we can see what the problem might be.
i have alot of videos that i am downloading from youtube
here is one of them:
http://www.sendspace.com/file/zx7ugb
by the way all of this videos works good on resolume 2.4.
Hi Arikz,
Your .avi file is an XVID file, really not the format you should be using for vjing.
Here it loads fine though, so make sure you have the proper codec installed.
Consider converting your files to mjpeg or our DVX codec.
- gpvillamil
A problem I've seen a lot of is when right codecs are installed, but the splitter is wrong. (The splitter is the driver that handles reading the file, separating audio & video tracks, and sending them to the decoder.)
Look in this thread for some tips:
viewtopic.php?f=12&t=3229&p=20128&hilit=gspot#p20128
thanks alot guys ! ill see if i can fix it
