Complete resolume novice here, so sorry if I'm being a bit slow or have this in the wrong place, but am I right in thinking that you can set the external fft input to allow effect parameter syncing from audio played in something like winamp on the same pc thats running resolume ?
Or have I got the wrong end of the stick ?
I noticed this post for resolume 2 http://www.gearwire.com/resolumeaudio.html
"Under Audio FFT, make sure your internal sound card driver is selected. Now, open Winamp, iTunes, or another media player and bring up a track"
Which made me think you could but I've been trying to set this up for ages with no luck. Running Win 7 with the on board Realtek sound from my LANPARTY JR 790GX-M3H5, when I go to audio preferences all I get to select from is "default audio capture driver" and "Realtek digital input", using the default and playing anything in winamp gives me no input at all, I've tried installing new drivers and playing different audio formats, I've also wacked the volume right up on Wimamp and maxed the gain in resolume but nothing seems to work.
Any help to get me running would be much appreciated. I'm sure I'm probably just missing something really basic and rubbish.
Thanks again
