is it possible to have a live stream from a website, have a client that wants a live feed from a flash stream, it's one of these sat nav streams that shows the progress of contestants in a race. being able to show a live webpage as a clip and then being able to zoom a particular region would be great is this possible?
thanks.
streaming from website
- rxfromparis
Re: streaming from website
Mac or Pc ??
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
- Tschoepler
Anything is possible
Can you publish a link to the webiste?
megawattmedia
- Tschoepler
Is your client the one who's running this site? Can you get your hands on the GPS information?
Do you want the stream inside Avenue to be as it is shown in your browser? As if you made a screen capture of it and import the movie into Avenue.
Do you want to modify the view inside of Avenue or the browser?
Do you have coding experiences?
megawattmedia
yes but they're fairly inflexible, and don't think they'll give me the gps information, it's a live feed that will be on a website i did think perhaps i could do a screen capture from another laptop but didn't know how i could feed this into a macbook pro. it's a tricky one. think it's going to be easiest to run the feed on another lappy though v4, just thought it would be nice to run it all through resolume and macbook pro.
- Tschoepler
I see
I suggest you have a look at vade's & bangnoise's new tool syphon. It's in private beta at the moment and I am not quite sure if it supports flash/browser yet. In theory it should work i guess. Contact one of em and ask. They know best.
megawattmedia
thanks that looks like it might do it, how do you actually get hold of it? just contact them for a beta version?
thanks,t.
thanks,t.
- Tschoepler
Asking kindly, yes
