I have a few microsoft lifecams that I'm trying to use in resolume 3.2
1 vx6000
one vx1000
and one hd6000
The hd 6000 and the vx6000 work ok, but I can't get them to capture as anything other than 640x480. If I try the settings on the clip I can change sharpness \ exposure \ etc, but there are no properties for resolution.
The vx1000 is a black screen, despite all three working ok in other applications.
Any assistance greatly appreciated!
Possible to set webcam resolution to other than 640x480?
Re: Possible to set webcam resolution to other than 640x480?
ive never managed to get mine running at anything other than 640 x 480, which is a shame as its an takes much higher rez
I don't have a USB camera to compare, but a PAL signal via a firewire camera source gives a 768 x 576 resolution, as expected. So, a capture device doesn't appear to be limited to 640 x 480 in Resolume.
just to be clear, i am also talking about a microsoft lifecam. it quite happily goes up to 720p in the supplied software but nothing other than 640 x 480 in avenue.
- rxfromparis
thx for the info, i was thinking of buying one, anybody know a HD webcam that works in Hd in Avenue ??
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
