Resolume Avenue and multi-core procs
sjp
Post by sjp »
Hey all,
I use video in theatrical projects and am currently using the (now discontinued) ArkaosVJDMX software.
Resolume seems to have everything we need and is still supported. We are now considering a switch and a rebuild of our current show and media server...
After having read all the documentation and about to start trial setups, I'd like to know if Resolume actually utilizes multi-core processors?
I have found some old forum (3yrs+ old) that state that it wasn't, but was wondering what the current state of multithreading support is..
Thanks,
sjp
Re: Resolume Avenue and multi-core procs
Hey SJP
The posts you read were indeed out of date, Avenue is multithreaded.
sjp
Post by sjp »
thank you very much!
levdog
Post by levdog »
Avenue might be multithreaded, but QuickTime on pc does not support multithreaded decoding.
Basic
Post by Basic »
levdog wrote:Avenue might be multithreaded, but QuickTime on pc does not support multithreaded decoding.
is it not the GPU that decodes when using this program?
Stickygreen
Post by Stickygreen »
If your Video Files are encoded in the .DXV codec, then yes the GPU will handle all the video decoding.
Basic
Post by Basic »
Stickygreen wrote:If your Video Files are encoded in the .DXV codec, then yes the GPU will handle all the video decoding.
cool i thought so... always best to have someone else say it is too :)
