Appreciate any help that you can provide.
I have a MacBookPro, late 2011 model with 1GB AMD Radeon HD 6770M, 16gb ram.
Ports are two USB 2.0, One Thunderbolt/MiniDisplay, One Firewire 800.
Here is my issue:
I am running Resolume Arena with advanced output for mapping to four surfaces.
I will be connecting 3 Sony EX3s to Panasonic HD switcher.
I need to get the HD switcher into Resolume - so I have a blackmagic intensity extreme to connect via Thunderbolt. That part is easy.
Here is the rub, since I am using the Thunderbolt port for input, I now have no means for output...
So, is there a recommended Firewire or USB capture device? Is there a thunderbolt device that will allow me to still output? I have looked at the Matrox MX02, which has daisy chaining but I am not sure that I can daisy chain to a display port adapter.
If this helps:
3 cams to switcher->
Switcher to "some capture device"->
Capture device loaded to resolume->
Resolume advance output mapping to projection
First date of the show I am doing is April 13th, so I need to figure this out fast! Any help you can provide is appreciated!
HELP! Video Input - MacBookPro
Re: HELP! Video Input - MacBookPro
I may have resolved my own issue. I decided to pickup the AJA io XT Thunderbolt. Since it has 2 thunderbolt ports I should be able to attach a display port adapter to the second port and feed that to projection using the internal video card. (fingers crossed!)
- Stickygreen
this is where the expresscard 34 slot on the 17" MacBook Pro really comes in handy..
I have the same issue so would love te hear the results on that one! It's quit an expensive device so would like to be sure it works...
Same issue here!
