Midi buttons work to turn effects on but not off
zebbler
Post by zebbler »
Finally got a midi controller and noticed this quite annoying bug (or is it a feature?).
I would love to fly through controlling global effects on my composition - to make everything change color or increase contrast or something, but I noticed that I can only turn the effect on with my midi buttons, but not off. It was a consistant behavior for me unfortunately. So I can't really use this in live performances unfortunately.
Can this be fixed? That would be so awesome!
I use Resolume 4.01 (I think it's the latest one at this moment)
Best,
Zebbler
mowgli
Re: Midi buttons work to turn effects on but not off
Post by mowgli »
which controller are you using and what are the buttons actually sending? cc's, notes, are they set to toggle?
that's probably the cause
1mpar
Post by 1mpar »
the problem is in the configuration of your controller, not in resolume. try to change the way it sends the note.
